MarcoG
Second extruder offset
Hello to all!
I'm Marco from Italy, i need a little help for configure the software, my printer configuration is:
Delta printer (like Rostock)
Two head
Ramps 1.4
Repetier firmware (last version)
Heads offsets are configured in firmware, h1 -10.8,0.0 h2 10.8,0.0
I can print with repetier and cura without any problem, but with simplify3d i can't configure the right offset, please help me!!!
Thanks!
bubbasnow
Re: Second extruder offset
with repetier i set the offset in eeprom, then i just enable the second extruder in processes. if you type t0 and t1 in the command window you should see that it pulls offsets and applies them from eeprom
