tanagentinnovations
G-Code So Extruder Tip Won't Stop on Top of My Print
Hello,
I recently purchased simplify and have a little issue. I'm coming from Slic3r software. Is there a generic G-Code function that will bring the extruder head to a home position after completing the print? As of now once the print is completed the tip stays on the bottom left corner of the print and since its hot, it leaves a minor print on the part itself. I want it to go home or away from the print after completion.
Also, besides rectilinear and concentric are there any more external patterns? Slic3r has some cool options, Simplify onlt has 2.
Thanks. ;)
rrdavis
Re: G-Code So Extruder Tip Won't Stop on Top of My Print
Just add a "G28 X0" to the top of your ending script.
This command is explained here:
https://www.simplify3d.com/support/arti ... orial/#G28
