I've problem printing a small object with dense support.
The object has on its base a little groove for a seeger ring, that doesn't need support.
This is the front view of the object:
The support has been placed automaticcally from build platform only:
using the following settings:
Simplify3d generates a dense support in air at the height of the seeger ring groove.
In the cross-section image below, the dense support is visible near the yellow bridge, between the support wall and the part:
This is a Y cross-section view of the entire object, the bottom dense ring support is placed on the air, and will never be printed correctly:
I've played a lot with parameters, but the issue still be present.
Any suggestion ?
Thank you.
Regards,
Gabriele.
