I'm relatively new to S3d and I'm having trouble with supports generated for the angled surface (61 deg from vertical)
First of all, as you can see, S3D generates small segments of support completely detached from anything, both from the model and from support. As expected, it produced a mess. Second, in the end it looked like the model was printed without support at all. In other words the model was pretty much disconnected from the support, with over 1mm of vertical separation. The only connection was through stray strings here and there. Any tips would be appreciated.
