RolfW
Corkscrew printing mode - pause at corners
Hello,
I am trying to print this polygonal pen holder in "corkscrew" / "vase" mode on my Cetus 3D printer:
https://www.thingiverse.com/thing:430689
I have noticed that when the extruder walks around the perimeter, at SOME corners of the polygonal outline it stops for half a second which results in ugly blobs. At other corners it just walks through as it should and no blobs appear.
Where does this pause come from and how can I deactivate it?
cheers,
Rolf
cetrespeo
Re: Corkscrew printing mode - pause at corners
Same problem here
AndersE
Are you printing via USB or SDcard?
I have micropauses around 0.5 sec on almost every print on both my printer (diff hardware) , and i print via USB. Have done so all the time, and pauses started after 4.0 and 4.01 install.
Just verifying what you use.
right now printing a drivecogsheel 60mm diameter, and it has already paused 3 times even before i have printed 30%.
Had to cancel last one because it blobbed so bad that the head crashed the print.
