Hello!
I´m from Austria with german as motherlanguage. So excuse me Language problems.
I have the software since 3 days. I spent much time to unterstand it. Normally i´m good in understanding software (technical engineer with program experience).
All problems i had with printing i found the solution.
But there is still one Problem.
When i want to save a factory file (save or save as), the software crash and the file is in the directory, but it´s empty.
After restart the software - this is also empty. So all work is gone.
I found something. This happens only after using once or more the "prepare to print" function.
Before i had never this error.
I tried much. (Language - because use german.....).
I reseted the software, i uninstalled the software with deleting everything. But not all was deleted because after re-install the software loaded the last settings! But i don´t think that it will help if i delete all registry entries or any other files.
I searched in the community but didn´t find something.
I have Windows 7-32 with the latest release of SF3D. 4.0.1
Maybe you have a solution for me!
Regards!
Dietmar
