Juancho
Z axis issue using MBOT
Hi everybody.
I have a MBOT, and when the 3d printer finished printing a model, the z axis instead of going to the bottom, the z axis rises a few centimeters. This is a problem when I want to print larger objects to 16cm, at the end the object is embedded in the still hot extruder and spoiling the printed pattern.
How can I fix it?
Joey
Re: Z axis issue using MBOT
In the process settings, go to the scripts tab. From there, go to the Ending G-code tab and find the line that says
G0 Z155 F1000 ; send Z axis to bottom of machine
Change that to
G0 Z200 F1000 ; send Z axis to bottom of machine
then print
