I'm printing a two color 3DBenchy on my TAZ 6 with the Dual V3 toolhead. At the top of the Cura Dual V3 start code I added:
M218 T0 X0 Y0 ; Simplify3D requires tool offsets in firmware
M218 T1 X0 Y0 ; offset for front extruder (set at end)
and at the end of the Cura Dual V3 start code I added:
M218 T1 X13.0 Y0.0 ; offset for front extruder
The complete start gcode I'm using (still needs a few more temperature [variables]):
G26 ; clear probe fail condition
G21 ; set units to Millimetres
M107 ; Stop the fan
G90 ; absolute positioning
M140 S[bed0_temperature] ; start heating bed
M104 S170 T0 ; start heating back extruder
M104 S170 T1 ; start heating front extruder
G28 X Y ; home X and Y
G1 X-17 F3000 ; clear X endstop
G1 Y258 F3000 ; move over the Z_MIN switch
G1 X-19 F3000 ; move left as far as possible
M109 S170 T0 ; soften filament for Z homing
M109 S170 T1 ; soften filament for Z homing
G28 Z ; home Z
T0 ; select this extruder first
M82 ; set extruder to absolute mode
G92 E0 ; zero extruder
G1 E-12 F100 ; retract 12mm filament
T1 ; switch extruders
T0 ; switch extruders
G1 X-17 Y100 F3000 ; move above wiper pad
G1 Z1 ; push nozzle into wiper
G1 X -18 Y95 F1000 ; slow wipe
G1 X -18 Y90 F1000 ; slow wipe
G1 X -18 Y85 F1000 ; slow wipe
G1 X -17 Y90 F1000 ; slow wipe
G1 X -18 Y80 F1000 ; slow wipe
G1 X -17 Y95 F1000 ; slow wipe
G1 X -18 Y75 F2000 ; fast wipe
G1 X -17 Y65 F2000 ; fast wipe
G1 X -18 Y70 F2000 ; fast wipe
G1 X -17 Y60 F2000 ; fast wipe
G1 X -18 Y55 F2000 ; fast wipe
G1 X -17 Y50 F2000 ; fast wipe
G1 X -18 Y40 F2000 ; fast wipe
G1 X -17 Y45 F2000 ; fast wipe
G1 X -18 Y35 F2000 ; fast wipe
G1 X -17 Y40 F2000 ; fast wipe
G1 X -17 Y30 Z2 F2000 ; fast wipe
G1 X -17 Y25 F2000 ; fast wipe
G1 X -18 Y30 F2000 ; fast wipe
G1 X -17 Y25 Z1.5 F1000 ; slow wipe
G1 X -18 Y23 F1000 ; slow wipe
G1 X -17 Z15 ; raise extruder
M204 S100 ; set accel for probing
G29 ; probe sequence (for auto-leveling)
M204 S500 ; set accel back to normal
G1 X100 Y-25 Z0.5 F3000 ; move to open space
M400 ; clear buffer
M117 Heating...
M104 S[extruder0_temperature] T0 ; start heating back extruder
M104 S[extruder1_temperature] T1 ; start heating front extruder
M190 S[bed0_temperature] ; stabilize bed
M109 S[extruder0_temperature] T0 ; stabilize back extruder
M109 S[extruder1_temperature] T1 ; stabilize front extruder
M117 Purging... ; LCD status message
G1 E0 F100 ; undo retraction
G92 E-15 ; set extruder negative amount to purge
G1 E0 F100 ; purge XXmm of filament
T1 ; switch to second extruder
G92 E-12 ; reset global extruder position (from above)
G1 Z0.5 ; clear bed (barely)
G1 X100 Y0 F5000 ; move above bed to shear off filament
T0 ; switch to first extruder
G1 Z2 E0 F75
M400 ; clear buffer
M117 TAZ Printing...
While slightly off topic, if anyone knows what to use for Cura's {material_soften_temperature_0}, {material_soften_temperature_1}, {material_wipe_temperature_0}, {material_wipe_temperature_1}, {material_probe_temperature_0}, and {material_bed_temperature_layer_0} I'd be happy to fix the constant 170 temps in the above start gcode.
