spencyg wrote:One thing I find especially interesting about the 3D printing community, and more specifically the resolution of problems within 3d printing forums is that for every question there are at least 2 conflicting answers. Some people say always do it this way, while others say never do it this way, do it that way....round and around.
So I'm seeing some folks say leave it at a 0,4mm width, others say you can vary the width depending on requirements. Some say set the multiplier so when you're printing a particular line width, the finished line actually prints exactly at that dimension while others throw that idea out the window and use the multiplier to make visual adjustments to the line segments.
I'm now in a position where I have tried adjusting the multiplier while leaving the width alone and adjusting the width while leaving the multiplier alone. I go from under extruding to over extruding when the multiplier is messed with, and adjusting line width doesn't seem to have an effect on gap. I'm going to mess around with it more this evening but I'm clearly an isolated case here since this doesn't seem to be a problem anybody has real world experience with. I'll print a few more samples with varied settings and post up some pics tomorrow.
I feel your pain! Part of the fun of this stuff is that there are very few good solid laws. Its all rules of thumb with many exceptions and a great deal of experimentation required. (thats also the frustrating part!)
Here's what i've learned:
The extrusion width affects the model slicing--this means that changing the extrusion width affects how closely the slicer spaces the tool paths in your model. It also recalculates the flowrate to try to give you the desired line thickness.
This means that JUST changing this parameter will likely give you largely the same results. it made your lines closer together, but also smaller.
The extrusion multiplier does NOT affect model slicing--only the flowrate. Also, very small tweaks give large results.
Once you have the correct extrusion width, the extrusion multiplier is used to dial it in.
If you are pulling filament around at direction changes, it SOUNDS like the viscosity of the material could be high--raising the temp slightly will help that--but of course that may cause other issues.
do check the INFILL tab: "The Minimum Infill Length" setting that is too high, can leave corner transitions hollow, as your model appears to have. Set this to a very small value and see what happens. Also make sure that the ADVANCED tab has "allow gap fill when necessary" selected.
As always, take forum advice(especially mine) with an appropriate grain of salt--most of us here are learning the same way you are. Enjoy the process and good luck! Keep us posted on your results, too!
