I would like to see an option to create angled supports.
For example let's say you have an overhang 3" above the bed. Instead of having supports growing up from the bed, you have supports that grow from the side of the part up at an angle to the overhang. 45-deg should work fine, although a selectable angle would be best.
Benefits: More stable supports when they need to reach high. Faster. Uses less material.
Cons: None that I can think of.
