After struggling with the new Aerostruder on my Lulzbot Taz 6 I think I have resolved most of the issues. Aleph Object's tech support are clueless sometimes and that really sucked but I managed to correct the PLA and even pulled off a wonderful first time NinjaFlex print yesterday.
Please note that I DID NOT do a PID autotune like Aleph Techs will tell you. The forum over there will even run you further astray so just keep the fan on a slow ramp because it is way more powerful than it should be. Its a blessing and a curse. The bridging is really good when you pop that fan to 100% (never run it above 80% normally).
Anyways, find my public repo here; https://github.com/youcangetme/Simplify ... esTaz6.git
*NOTE: The only alterations I made to the factory settings after flashing the new Aerostruder firmware and following the directions to reset the EEPROM is to adjust the steps for the extruder. I printed the 20mm cube in the STL directory of my repo until the top layers sealed up and I couldn't blow air through it using my lips (highly scientific lips there
**NOTE: Only the profiles marked with the word "Aerostruder" are tuned to the Aerostruder.
I hope this will help others. The PLA Pro is easily converted to plain PLA by adjust the extruder temp. ABS will be a variation of that and when I get to an ABS project I will publish those as well.
Blue Skys!
--jb
