First of all, I like Simplify 3D a lot. It maximizes my control over my printers to get the best results.
However, I am having troubles with models where Simplify 3D V4.01 just seems to skip on parts on otherwise will leave openings in prints that should not be there.
In most cases, I just resort to Cura to print them and this has worked out fine every time.
Last week I had such a case where a batch of parts I printed for a customer were missing a small edge at the end of the print. S3D simply did not print it.
Now I have another example: A lightweight drone frame designed by a customer simply won't print correctly in S3D.
As you can see in the pictures, S3D will not continue the outside layers and/or not fill in the space between them.
I have tried every setting combination I could think of
Shell: Single Extrusion Walls or Perimeters don't matter.
Infill: Perimeters Only, Single Extrusion Walls or Allow Gap Fill, it will still not connect the outline correctly.
Same STL-file prints fine with Cura, even the old version that I have.
