GHT77
Feature Request : Extruder speed control
Feature request : extruder speed controls
Allow changes to the extruder motor speed. When upgrading to a geared extruder (such as a E3D titan) the extrusion rate decreases for added torque. For example:
Stock Direct Drive extruder is a 1:1 gear ratio
Geared extruder is 1:3 ratio (would need to increase motor speed 3x to achieve correct extrusion rates)
rrdavis
Re: Feature Request : Extruder speed control
You can already adjust the steps/mm values in the Tools > Firmware Configuration window as explained in your other post:
viewtopic.php?f=8&t=9830#p40982
