Hello, been having this problem since the release of 4.0.
When S3D processes a vertical radius it creates a jagged inner wall (see pics below) vs a smooth line which is causing shifting layers from the violent vibration. I have duplicated this several times and is very consistent. In order to correct this I have to either change the infill to concentric or change the Extrusion Width to manual and increase the size to .80
This solution works on larger parts but needs some tweaking on smaller parts as the inner wall diameter changes. I am always having to check STL files for radius anomalies so I can plan ahead which is becoming a real PIA as if I miss one than I risk shifting layers during a long print job.
I know this is not an isolated case and S3D should be aware of the issue and have corrected this by now. I did not have this problem with earlier version of S3D and have been a user for about 3 years now.
Appreciate if anyone has a permanent fix or advise if this has been reported as a bug.
Dennis
