It turns out, after some investigation, that you can configure saving settings according to your requirements by manually editing the FFF profile. This is also required to correctly set up a profile for dual extrusion.
The FFF Profile
The profile you'll be editing is generated from the stored settings within the S3D app. To generate the file based on your current or saved profile settings, use 'export FFF profile' from the file menu and select the appropriate profile.
While the file extension is .fff, it is in fact a standard XML file. The XML format typically represents data, stored between opening and closing tags, the same way that HTML code is formed. You'll neeed to be comfortable working with this type of file and not to introduce syntax errors while editing. For a quick briefing about XML, visit https://www.w3schools.com/xml/default.asp
A suitable tool for working with XML is available free and online at https://codebeautify.org/xmlviewer. This will allow you to check to make sure that your XML markup is valid and will give you clues where to look in the code if you have made a mistake. Paste your profile into the left side code window, and click 'Tree View' to display data. Any error will be highlighted in the right side view.
If you make a mistake with coding the XML correctly, it appears that S3D will not let you know about the errors when importing the file back in. In this case you will probably end up with some abnormal settings behaviour, so my tip is not to make these kind of mistakes, okay.
To use your edited profile in the S3D app, use 'import FFF profile' from the file menu. If you have not edited the name of the exported profile, S3D creates a numbered version of the profile with the same name and will tell you when import is complete.
Settings and parameters
Just to be clear, I am differentiating between a setting and a parameter when it comes to what you are required to edit manually. Consider the following:
Code: Select all
<globalExtruderTemperature>225</globalExtruderTemperature>
Once you have the parameter listed inside the approriate auto Config parameters, you will be able to make any future settings changes within the S3D app.
Auto configuration settings controls
Up to three auto-configure dropdowns are visible below the profile selection dropdown. If you have a fully configured profile, you'll have material, quality and extruders. If you don't see a particular dropdown this indicates that the appropriate sections have not been included or have been removed from your currently selected FFF profile.
To show the material dropdown you have to have at least one material in the FFF profile. This is a default entry:
Code: Select all
<autoConfigureMaterial name="ABS">
<globalBedTemperature>100</globalBedTemperature>
<globalExtrusionMultiplier>1</globalExtrusionMultiplier>
<fanSpeed>
<setpoint layer="1" speed="0"/>
</fanSpeed>
</autoConfigureMaterial>
Code: Select all
<autoConfigureQuality name="Fast">
<layerHeight>0.3</layerHeight>
<topSolidLayers>3</topSolidLayers>
<bottomSolidLayers>3</bottomSolidLayers>
<skirtLayers>1</skirtLayers>
<infillPercentage>15</infillPercentage>
<supportInfillPercentage>25</supportInfillPercentage>
</autoConfigureQuality>
The final dropdown will only appear if you have configured the profile for dual extrusion by manually editing an FFF profile.
What is stored in auto configuration by default?
The following settings are stored and recalled with changes to the dropdown selections....
Material
- Extruder temp
- Bed temp
- Extrusion multiplier
- Fan speed
- Layer height
- Top solid layers
- Bottom solid layers
- skirt layers
- Infill %
- Support infill%
- Primary Extruder
- Raft extruder
- Skirt extruder
- Infill extruder
- Support extruder
- Skirt?
- Prime Pillar?
- Ooze shield?
- Temp controller used
- Start Gcode
How do you store other settings with these configurations?
If you manually edit and add a settings parameter to a material, quality or extruder auto configure entry, this setting will be saved with whatever you have listed in these dropdowns. It's not important what the settings are as you add them as once the parameter has been added you will be able to edit the settings for each selected dropdown as you require.
For example, I have added all of the parameters that I'd like to have saved for a material entry:
Code: Select all
<!--Modifications saved with this material (all optional):-->
<!--Extruder Tab - duplicate the entries for your extruders if required-->
<extruder name="Right Extruder">
<toolheadNumber>0</toolheadNumber>
<autoWidth>1</autoWidth>
<width>0.48</width>
<extrusionMultiplier>1</extrusionMultiplier>
<useRetract>1</useRetract>
<retractionDistance>1</retractionDistance>
<extraRestartDistance>0</extraRestartDistance>
<retractionZLift>0</retractionZLift>
<retractionSpeed>1800</retractionSpeed>
<useCoasting>0</useCoasting>
<coastingDistance>0.2</coastingDistance>
<useWipe>0</useWipe>
<wipeDistance>5</wipeDistance>
</extruder>
<extruder name="Left Extruder">
<toolheadNumber>1</toolheadNumber>
<width>0.48</width>
</extruder>
<!--Layer Tab-->
<firstLayerHeightPercentage>100</firstLayerHeightPercentage>
<firstLayerWidthPercentage>100</firstLayerWidthPercentage>
<firstLayerUnderspeed>0.75</firstLayerUnderspeed>
<!--Additions Tab-->
<useRaft>0</useRaft>
<raftExtruder>1</raftExtruder>
<raftTopLayers>3</raftTopLayers>
<raftBaseLayers>1</raftBaseLayers>
<raftOffset>3</raftOffset>
<raftSeparationDistance>0.1</raftSeparationDistance>
<raftTopInfill>100</raftTopInfill>
<aboveRaftSpeedMultiplier>0.3</aboveRaftSpeedMultiplier>
<!--Infill Tab-->
<internalInfillPattern>Fast Honeycomb</internalInfillPattern>
<externalInfillPattern>Rectilinear</externalInfillPattern>
<infillPercentage>40</infillPercentage>
<outlineOverlapPercentage>15</outlineOverlapPercentage>
<infillExtrusionWidthPercentage>100</infillExtrusionWidthPercentage>
<minInfillLength>5</minInfillLength>
<infillLayerInterval>1</infillLayerInterval>
<internalInfillAngles>0</internalInfillAngles>
<overlapInternalInfillAngles>0</overlapInternalInfillAngles>
<externalInfillAngles>0,45,90</externalInfillAngles>
<!--Temperatures Tab - duplicate the entries for your temp controllers if required-->
<temperatureController name="Right Extruder Temperature">
<temperatureNumber>0</temperatureNumber>
<isHeatedBed>0</isHeatedBed>
<relayBetweenLayers>0</relayBetweenLayers>
<relayBetweenLoops>0</relayBetweenLoops>
<stabilizeAtStartup>1</stabilizeAtStartup>
<setpoint layer="1" temperature="260"/>
</temperatureController>
<temperatureController name="Left Extruder Temperature">
<temperatureNumber>1</temperatureNumber>
<temperatureController name="Heated Bed">
<temperatureNumber>2</temperatureNumber>
<isHeatedBed>1</isHeatedBed>
<setpoint layer="1" temperature="110"/>
<globalBedTemperature>110</globalBedTemperature>
<!--Cooling Tab-->
<fanSpeed>
</fanSpeed>
<blipFanToFullPower>0</blipFanToFullPower>
<adjustSpeedForCooling>1</adjustSpeedForCooling>
<minSpeedLayerTime>10</minSpeedLayerTime>
<minCoolingSpeedSlowdown>20</minCoolingSpeedSlowdown>
<increaseFanForCooling>0</increaseFanForCooling>
<minFanLayerTime>45</minFanLayerTime>
<maxCoolingFanSpeed>100</maxCoolingFanSpeed>
<increaseFanForBridging>0</increaseFanForBridging>
<bridgingFanSpeed>100</bridgingFanSpeed>
<!--Speeds Tab-->
<!--Other Tab - Bridging-->
<minBridgingArea>50</minBridgingArea>
<bridgingExtraInflation>0</bridgingExtraInflation>
<bridgingExtrusionMultiplier>0.95</bridgingExtrusionMultiplier>
<bridgingSpeedMultiplier>0.5</bridgingSpeedMultiplier>
<useFixedBridgingAngle>0</useFixedBridgingAngle>
<fixedBridgingAngle>0</fixedBridgingAngle>
<applyBridgingToPerimeters>1</applyBridgingToPerimeters>
<!--Other Tab - Tool Change Retraction-->
<toolChangeRetractionDistance>17</toolChangeRetractionDistance>
<toolChangeExtraRestartDistance>0.5</toolChangeExtraRestartDistance>
<toolChangeRetractionSpeed>600</toolChangeRetractionSpeed>
<!--Advanced Tab - Ooze Control-->
<onlyRetractWhenCrossingOutline>0</onlyRetractWhenCrossingOutline>
<retractBetweenLayers>0</retractBetweenLayers>
<useRetractionMinTravel>0</useRetractionMinTravel>
<retractionMinTravel>3</retractionMinTravel>
<retractWhileWiping>0</retractWhileWiping>
<onlyWipeOutlines>1</onlyWipeOutlines>
What settings parameters are available?
All settings are shown in the default FFF profile. They are jumbled around a bit but there is a grouping of logical settings if you look hard enough.
If you look at the complete profile I've created (see The Profile below) individual parameters are listed in Section 6. In addition, you can add the following group parameters:
- <extruder> (Section 1)
- <temperatureController> (Section 2)
There are only a couple of important things to bear in mind as you organise what you want saved with which autoconfiguration entry:
Duplicated parameters
You can add a named parameter to either <autoConfigureQuality>, <autoConfigureMaterial> or <autoConfigureExtruders> but you can add it to just ONE of those groups.
Group entries
Parameter groups include <extruder>, <temperatureController> and <fanSpeed>. You can't add individual child entries of a group entry as settings on their own. If you add a parameter group, S3D saves all child settings within the group. You can define the children when editing or S3D will do it for you first time it saves.
Incorrect
Code: Select all
<diameter>0.4</diameter>
<width>0.48</width>
Code: Select all
<width>0.48</width>
</extruder>
Code: Select all
</extruder>
I have created a profile, reorganised, formatted and annotated, to help you get started customising this to your needs. I have it set up for a MendelMax3, and for my own workflow, so if you share the same tastes, you won't need to do much with the code .
Code: Select all
<?xml version="1.0"?>
<!--If setting up from scratch edit this file first, following guidance notes, then import this profile into S3D-->
<!--Edit settings, duplicate(add) new materials and quality settings according to taste-->
<!--You will lose all of the comments in this file during import, so edit and keep this as your master copy-->
<!--Use an approriate name for your profile-->
<profile name="MM3 Dual Extruder" version="2018-04-11 23:25:36" app="S3D-Software 4.0.1">
<baseProfile>MM3 Dual Extruder</baseProfile>
<!--If you save as new profile in app, this will be the base name for all of your derived profiles-->
<!--Optional:-->
<!--To display your own printer model in the application-->
<!--Place model STL in <Application Directory>\platforms-->
<!--Refer to appropriate STL file below-->
<overridePrinterModels>0</overridePrinterModels>
<printerModelsOverride>mendelmax3.stl</printerModelsOverride>
<!--Define each extruder and heating controller for your specific printer-->
<!--The name given is not significant - call it something logical for your printer-->
<!--These definitions can be modified by material, quality and extruders configuration dropdowns-->
<!--Section 1 - Extruders-->
<width>0.48</width>
</extruder>
<width>0.48</width>
</extruder>
<!--Section 2 - Temperature controllers-->
<!--Section 3 - Extruder Dropdown-->
<!--For a single extruder, this section is not required-->
<!--Dual Extruder configuration, in this profile, Tool 0 is on RHS-->
<!--Make sure that tool and temp ids are consistent in each of these sections-->
<autoConfigureExtruders name="Right Extruder Only" allowedToolheads="1">
<!--Required parameters - refer to controller name in section 2-->
<toggleTemperatureController name="Right Extruder Temperature" status="on" stabilize="on"/>
<toggleTemperatureController name="Left Extruder Temperature" status="off" stabilize="on"/>
<primaryExtruder>0</primaryExtruder>
<raftExtruder>0</raftExtruder>
<skirtExtruder>0</skirtExtruder>
<infillExtruder>0</infillExtruder>
<supportExtruder>0</supportExtruder>
<!--Optional parameters-->
<useSkirt>1</useSkirt>
<usePrimePillar>0</usePrimePillar>
<useOozeShield>0</useOozeShield>
<startingGcode>G28 ; home all axes,G29 ; Bed Level,G1 Z5 F5000 ; lift nozzle</startingGcode>
</autoConfigureExtruders>
<autoConfigureExtruders name="Left Extruder Only" allowedToolheads="1">
<toggleTemperatureController name="Right Extruder Temperature" status="off" stabilize="on"/>
<toggleTemperatureController name="Left Extruder Temperature" status="on" stabilize="on"/>
<primaryExtruder>1</primaryExtruder>
<skirtExtruder>1</skirtExtruder>
<infillExtruder>1</infillExtruder>
<supportExtruder>1</supportExtruder>
<autoConfigureExtruders name="Both Extruders" allowedToolheads="2">
<usePrimePillar>1</usePrimePillar>
<useOozeShield>1</useOozeShield>
<!--For 'Materials' and 'Quality' dropdowns, selection changes any setting listed as a parameter of that material or quality-->
<!--Parameters can include nearly all settings listed at the end of this config file-->
<!--To add parameters, duplicate entry (and, in the case of child entries, all children)-->
<!--** Parameters cannot be listed in both material and quality **-->
<!--Any parameters not listed will remain unchanged regardless of dropdown modifcations-->
<!--This profile organises the various settings into what makes sense to the author to separate material and quality settings.-->
<!--Suggest you start with one material profile and one quality profile in FFF, duplicating within the app as required -->
<!--Section 4 - Materials Dropdown-->
<width>0.48</width>
</extruder>
<width>0.48</width>
</extruder>
<!--Layer Tab-->
<!--Infill Tab-->
<!--Cooling Tab-->
<fanSpeed>
</fanSpeed>
<!--Speeds Tab-->
<!--Section 5 - Quality Dropdown-->
<!--Naming convention used here: <Layer Height> <Default Speed> <Strength>-->
<autoConfigureQuality name="0.3mm - Fast - Regular">
<!--Modifications saved with this quality (all optional):-->
<defaultSpeed>4200</defaultSpeed>
<outlineUnderspeed>0.75</outlineUnderspeed>
<solidInfillUnderspeed>0.75</solidInfillUnderspeed>
<supportUnderspeed>0.8</supportUnderspeed>
<infillPercentage>20</infillPercentage>
<perimeterOutlines>2</perimeterOutlines>
<autoConfigureQuality name="0.25mm Medium Regular">
<defaultSpeed>3600</defaultSpeed>
<layerHeight>0.25</layerHeight>
<topSolidLayers>4</topSolidLayers>
<bottomSolidLayers>4</bottomSolidLayers>
<autoConfigureQuality name="0.2mm Medium Regular">
<layerHeight>0.2</layerHeight>
<infillPercentage>30</infillPercentage>
<autoConfigureQuality name="0.25mm Medium Strong">
<infillPercentage>50</infillPercentage>
<perimeterOutlines>4</perimeterOutlines>
<!--Section 6 - Current settings-->
<printMaterial>ABS</printMaterial>
<printQuality>Standard Quality</printQuality>
<printExtruders>Both Extruders</printExtruders>
<printPerimetersInsideOut>1</printPerimetersInsideOut>
<startPointOption>3</startPointOption>
<startPointOriginX>110</startPointOriginX>
<startPointOriginY>300</startPointOriginY>
<sequentialIslands>0</sequentialIslands>
<spiralVaseMode>0</spiralVaseMode>
<skirtExtruder>999</skirtExtruder>
<skirtOutlines>2</skirtOutlines>
<skirtOffset>4.4</skirtOffset>
<primePillarExtruder>999</primePillarExtruder>
<primePillarWidth>6</primePillarWidth>
<primePillarLocation>7</primePillarLocation>
<primePillarSpeedMultiplier>1.25</primePillarSpeedMultiplier>
<oozeShieldExtruder>999</oozeShieldExtruder>
<oozeShieldOffset>2</oozeShieldOffset>
<oozeShieldOutlines>2</oozeShieldOutlines>
<oozeShieldSidewallShape>2</oozeShieldSidewallShape>
<oozeShieldSidewallAngle>30</oozeShieldSidewallAngle>
<oozeShieldSpeedMultiplier>1</oozeShieldSpeedMultiplier>
<generateSupport>0</generateSupport>
<supportInfillPercentage>30</supportInfillPercentage>
<supportExtraInflation>0</supportExtraInflation>
<supportBaseLayers>0</supportBaseLayers>
<denseSupportExtruder>1</denseSupportExtruder>
<denseSupportLayers>1</denseSupportLayers>
<denseSupportInfillPercentage>70</denseSupportInfillPercentage>
<supportLayerInterval>1</supportLayerInterval>
<supportHorizontalPartOffset>0.3</supportHorizontalPartOffset>
<supportUpperSeparationLayers>1</supportUpperSeparationLayers>
<supportLowerSeparationLayers>1</supportLowerSeparationLayers>
<supportType>0</supportType>
<supportGridSpacing>4</supportGridSpacing>
<maxOverhangAngle>45</maxOverhangAngle>
<supportAngles>0</supportAngles>
<fanSpeed>
</fanSpeed>
<use5D>1</use5D>
<relativeEdistances>0</relativeEdistances>
<allowEaxisZeroing>1</allowEaxisZeroing>
<independentExtruderAxes>0</independentExtruderAxes>
<includeM10123>0</includeM10123>
<stickySupport>1</stickySupport>
<applyToolheadOffsets>0</applyToolheadOffsets>
<gcodeXoffset>0</gcodeXoffset>
<gcodeYoffset>0</gcodeYoffset>
<gcodeZoffset>0.1</gcodeZoffset>
<overrideMachineDefinition>1</overrideMachineDefinition>
<machineTypeOverride>0</machineTypeOverride>
<strokeXoverride>230</strokeXoverride>
<strokeYoverride>310</strokeYoverride>
<strokeZoverride>195</strokeZoverride>
<originOffsetXoverride>0</originOffsetXoverride>
<originOffsetYoverride>0</originOffsetYoverride>
<originOffsetZoverride>0</originOffsetZoverride>
<homeXdirOverride>-1</homeXdirOverride>
<homeYdirOverride>-1</homeYdirOverride>
<homeZdirOverride>-1</homeZdirOverride>
<flipXoverride>1</flipXoverride>
<flipYoverride>-1</flipYoverride>
<flipZoverride>1</flipZoverride>
<toolheadOffsets>0,0|0,0|0,0|0,0|0,0|0,0</toolheadOffsets>
<overrideFirmwareConfiguration>1</overrideFirmwareConfiguration>
<firmwareTypeOverride>RepRap (Marlin/Repetier/Sprinter)</firmwareTypeOverride>
<GPXconfigOverride>r2</GPXconfigOverride>
<baudRateOverride>250000</baudRateOverride>
<overridePrinterModels>1</overridePrinterModels>
<printerModelsOverride>Simplify3DPrinterModel.stl</printerModelsOverride>
<layerChangeGcode></layerChangeGcode>
<retractionGcode></retractionGcode>
<toolChangeGcode></toolChangeGcode>
<endingGcode>M104 S0 ; turn off temperature,M140 S1; turn off bed heater,M106 S0; disable fan,G91 ; set to relative positioning,G1 Z5 F5000 ; lift nozzle,G90 ; set to absolute positioning,G1 Y300 F5000 ; Eject Bed,M84 ; disable motors</endingGcode>
<exportFileFormat>gcode</exportFileFormat>
<celebration>0</celebration>
<celebrationSong>Random Song</celebrationSong>
<postProcessing></postProcessing>
<defaultSpeed>4500</defaultSpeed>
<rapidXYspeed>6000</rapidXYspeed>
<rapidZspeed>1002</rapidZspeed>
<filamentDiameters>1.75|1.75|1.75|1.75|1.75|1.75</filamentDiameters>
<filamentPricesPerKg>46|46|46|46|46|46</filamentPricesPerKg>
<filamentDensities>1.25|1.25|1.25|1.25|1.25|1.25</filamentDensities>
<useMinPrintHeight>0</useMinPrintHeight>
<minPrintHeight>0</minPrintHeight>
<useMaxPrintHeight>0</useMaxPrintHeight>
<maxPrintHeight>13.75</maxPrintHeight>
<useDiaphragm>0</useDiaphragm>
<diaphragmLayerInterval>20</diaphragmLayerInterval>
<robustSlicing>1</robustSlicing>
<mergeAllIntoSolid>0</mergeAllIntoSolid>
<avoidCrossingOutline>0</avoidCrossingOutline>
<maxMovementDetourFactor>3</maxMovementDetourFactor>
<externalThinWallType>1</externalThinWallType>
<internalThinWallType>1</internalThinWallType>
<thinWallAllowedOverlapPercentage>20</thinWallAllowedOverlapPercentage>
<singleExtrusionMinLength>0.9</singleExtrusionMinLength>
<singleExtrusionMinPrintingWidthPercentage>40</singleExtrusionMinPrintingWidthPercentage>
<singleExtrusionMaxPrintingWidthPercentage>200</singleExtrusionMaxPrintingWidthPercentage>
<singleExtrusionEndpointExtension>0.2</singleExtrusionEndpointExtension>
<horizontalSizeCompensation>0</horizontalSizeCompensation>
</profile>
If, like me, you have to set up your own dual extrusion profile, don't panic. Use Section 1 to 3 as a template, making sure to modify tool identification according to your machine's build.
