Isty_szy
Varible later hight external wall
Hello, i was wondering would it be possible to have a feature where we could set the external layer of the printed object o be 1/2 of the print layer, so that the you get fast print and increase the aesthetics of the print.
So if you have a wall of 2 layer thick and 0.2 mm height, the external wall layer will be printed with 0.1 mm height.
Just a thought.
rrdavis
Re: Varible later hight external wall
This already exists. Set your layer height to 0.1mm, then go to the Infill tab and change the setting to "combine infill every 2 layers". That way it will print two fine 0.1mm outlines and then one thick 0.2mm infill layer. You get high quality and fast printing speed :D
