I bought S3D last week and I'm loving the capabilities but I have one problem I can't seem to solve. The attached shows the problem. I created this simple model to test stringing since I've seen it on my regular prints. The print on the left is from S3D and the one on the right is from IdeaMaker. I've never had a problem with stringing in IdeaMaker but I can't seem to get rid of it with S3D even when I try to set the settings as close to what I'm using in IdeaMaker as possible. The attached was printed with .2mm layer height on both programs with the default print speed set to 60mm/s at 195 temperature which has always worked well for the PLA I'm using.
What I've tried:
Tried setting all retraction parameters the same as IdeaMaker including amount, z-hop, etc.
Tried manual extrusion with .48 (same as IdeaMaker)
Tried extrusion multipliers from 0.9 through 1.0
Tried slowing the print speed down and speeding it up
Tried lowering the temp to 180 even though IdeaMaker prints it fine at 195
Tried the wipe nozzle option
Both programs are set for retraction, 5mm distance, 0.5 z-hop, but I've tried various settings to no avail
None of those make any difference. I still get the same amount of stringing pictured with S3D. With IdeaMaker, I just get no stringing at all, or maybe one or two strands in an entire print at most.
There must be some setting I haven't tried?
Thanks for any help!
Mike
