wow "Joey" great finds!Joey wrote:Couple more finds.
1.
Tools-->options-->preferences
Disable automatic USB device detection. This will be nice for when doing an SD card print, so if you plug in your printer it wont reset the printer.
2.
Also, there's file association support. Right click an stl or factory file, open with-->simplify3d (set as default program). Now when you download an stl or factory file, you can click it and it will open+import to Simplify3d.
I got lucky, I check every once in a while whenever I remember to.dennisjm wrote:How did you find it since when I did check for updates it said it's still up to date. I was able to download it but since it isn't listed anywere?...
You just click to re-download every day?
