Sigge
CR10 mini configuration doesn't work
Hi, I have a CR10 mini and downloaded the CR10 mini configuration via the assistant.
To make it work with my printer I had to change the X and Y build volume dimensions.
X from 300 to 220 mm
Y from 220 to 300 mm
Z 300 mm
When I print something big nothing gets printed beyond Y 230 mm, i.e. 70 mm short of the build volume.
Anyone have any ideas on how to fix this?
Re: CR10 mini configuration doesn't work
What firmware-system is running on the CR?
Perhaps the movement area of the printhead is limited.
here the example of my Anet A8 with Marlin:
// @section machine
// Travel limits after homing (units are in mm)
#define X_MAX_POS 220
#define X_MIN_POS -33
#define Y_MAX_POS 220
#define Y_MIN_POS -10
#define Z_MAX_POS 240
#define Z_MIN_POS 0
Regards
GER
Sigge
So after a good night's sleep I figured it out...
The labeling on the cables for the X & Y connections were wrong from factory...
I switch them and now it prints on the whole surface with original CR 10 mini configuration from the assistant.
Thanx for the tip horst!
:D
/Sigge
Well done!
Happy printing :D
H
