I have a model whereby I need to nest parts and print different processes
Its modelled in Inventor in the correct position...you can see the second model in blue outline
When I import, they are not in the correct position
I apply reset position
Then align objects
no go.
I have tried importing the combined pieces (2 separate bodies and using separate connected, which would make a lot of sense. It works if I have a small test model but not on this model? I can still see the 2 elements but no separation can be applied? I guess they must lay within tolerance.
For modelling purposed, the general form is just a 10 layer perimeter etc...then reinforcing sections are modelled separately depending on requirements so I would like to keep the same workflow where I simply apply solid print parameters to specific objects
