Robin0
ambient temperature in material chart
Hi S3d Team.
Thank you for the wonderful material reference chart under https://www.simplify3d.com/support/mate ... ies-table/ . I often use this for reference when chosing material and finding the right material settings.
Would it be possible fo you to add to this chart the line "ambient room temperature" that suggests the surrounding temperature at which the different materials should be printed?
I can nowhere find detailed information about this matter. Only genereal information like "high for ABS" or "low, but not too low" for PLA.
Thank you in advance,
Robin0
Dremel 3D40
Prusa i3 MK3
- This is about as useful as rearranging the deck chairs on the Titanic. -
DarthRevan
Re: ambient temperature in material chart
I've seen in several other forums or guides that heated chambers are recommended for certain filaments, those too don't usually give an exact temperature. Humidity and air circulation should also be accounted for in a perfect controlled environment.
