dibble
Qiditech 1 USB printing not working
I have a new Qiditech 1 printer. When I save files out to SD card everything works fine. But, when I try to send the same job out over USB, only the right extruder heats up. The left extruder and the bed stay ice cold.
I don't know what's going on behind the scenes in S3D. But, I didn't think there was any difference in the output to SD vs USB. But, I guess so. Any ideas if there's a post-processing script I need to run, or some other G-code changes to make when going over USB?
I did see the other thread about a firmware bug requiring comments to be stripped. So, I have tried with and without adding {STRIP ";"} to the post processing script. But, this makes no difference.
Is anyone else able to print to Qiditech 1 over USB?
