pwalker4
End Script not working
When a print finishes the hot end just sits where it stops printing, usually still in contact with the object. Do I have to enable the start and end scrip's some how?
G28 X10 ; home X-axis
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motors[quote
Thank you for any help
greybeard
Re: End Script not working
G28 is 'Home All'. You're confusing it by adding X10.
You want to use G1:
G1 X10
3D Print Parts
airscapes
This is what is in the default end scrip for MakerGear M2
G91 ; relative mode
G1 Z10 ; lift 10mm
G90 ; absolute mode
G28 X0 ; home X axis
