Prusa just released firmware 3.2 (it's out of beta) and one of the biggest updates is the enabling of Linear Advance & Linear Correction. Is there any suggestions on how or if I need to enable this in my S3D profile?
I have an MK2. On mine as long as linear advance is enabled in the firmware then I just add the "K" value I want to use to my start script such as
M900 K40
Thanks I just did some searching and found the command
M900 K{if printer_notes=~/.*PRINTER_HAS_BOWDEN.*/}200{else}30{endif}; Filament gcode
this is out of the slicr fillement gcode setting.. this is new to me as I only had my Mk3 a few months so Linear advance is new and I believe it has been re introduced in latest FW..
not sure how to use it as the command above is in there profile for individual Filaments so in Gcode do I put a
M900 K (and then a value) ??? but what value... I keep looking about
Have read your link I understand now will do a test print of the Gcode and put the M900 command with the K value into my start code for the material I'm using ?? hope it works
