If you double-click on the part, a window will pop up...and in the window, you can manually select the part position, scale and rotation....so getting the rotation to 90 degrees is simple.I can get the mouthpiece up to 89 degrees but not an exact 90 degree.
To expand on Doug's suggestion.dkightley wrote: ↑Wed May 16, 2018 5:44 amIf you double-click on the part, a window will pop up...and in the window, you can manually select the part position, scale and rotation....so getting the rotation to 90 degrees is simple.I can get the mouthpiece up to 89 degrees but not an exact 90 degree.
Best thing would be to create a factory file....File dropdown menu===>Save Factory File. Attach the file to a post on this thread.....look below the box you type text into when posting & you'll see "Attachments". Click that tab!Can I attach a stl file anywhere for the community to look at?
