When Simplify3D changes process, it seems to miss two layers on the support. As shown in sketches, it clearly shows where the layers are applied right after the change of process 2 to 3. At the third layer, the support suddently resumes. This makes the layer of the support printed into air and creates havoc on the building of the part.
The different colors represent the 3 different processes. The main change between process 2 and 3 is in the layer thickness. I start with a layer thickness of 0.3 to finish with 0.1mm.
I can send my GCode and factory files if needed.
Do you have a solution for this problem?
Regards,
Robert
