OSX 10.11.6
S3D 4.0.1
I have a model that needs one type of support for the first 6mm of the print, then I change to another process for 6mm and up.
When I click prepare to print using both processes, the app crashes. Each process on its own works fine, so I know the processes are working. Maybe something to do with the start/stop distances? Does there need to be a gap?
I set process 1 to print from 0.00 to 6.00mm and process 2 is set to print from 6.00 with no upper bound. I later tried process 2 starting at 6.01mm with no better luck.
Any ideas?
