I have a MakerGear Prusa Mendel. I'm new in the world of 3D printing. But I know that to have a printer working properly it must be calibrated according to the program slicer. Well, I searched for a tutorial for the Calibration Software Creator and found nothing related.
What is the procedure for calibrating the Creator with a running MG Prusa Mendel? Should I use the same procedure adopted for the Slic3r in: https://github.com/alexrj/Slic3r/wiki/Calibration?
I'm using ABS and PLA with 1.75 mm. My MG Prusa produced better results with the Creator and ABS. I would calibrate for both materials.
Thanks for any help. You did an amazing job with the Creator.
P.S.
1) I noticed that there is a delay of several seconds when the printer goes from the first to the second layer. Is this normal?
2) Please forgive me if I was not clear. I'm using Google translator to communicate with you. I'm from Brazil I do not speak English.
