I have 2 objects I wanted to stack on top of each other for a dual extrusion print...... so when I started to work on this I noticed something odd.....
Both objects indicate in the interface that they are 2mm high. However, if I have the app put the one object flat on the bed, and then position the next object 2mm above it, there is a gap ?
I am trying to understand why this is so. I've looked for stray elements in each object messing up the z-axis, but I don't see any
If the first object is flat on the bed, and is 2mm high, then the next object should start as 2mm on the axis to be flush with the first. but this doesn't seem to be the case
thanks in advance for any help....
