KevinH
Custom setting for layer 1-3
Hi Guys,
I am aware that you can easily change temperature setting for individual layers. I am hoping to add a custom script for layer 1 - 3 to set print speeds to 33%, decrease temperature to 215 and turn the fan to 100%.
What is the most efficient way of adding this to a profile without having to manually open the G-code in a text editor after creation, Can I use layer scripts to do this?
Thank!
Regards,
Kevin
Re: Custom setting for layer 1-3
Have a read of this article: https://www.simplify3d.com/support/arti ... f-a-model/
What you want to do is described in it.
