innkeeper
temerature graph
is there a way to change the upper limit of the temperature graph?
dvalentim
Re: temerature graph
Good question! I would also like to know that. It seems that there is setting to work with ABS. The limit is 200 º C.
Simplify3D
Site Admin
The temperature plot scales automatically. If you temperature goes up to 207 degrees, it will automatically expand the y-axis go to up to 210 degrees or whatever it needs to capture the data. In general, it tries to maintain the smallest size possible so that your visual resolution is the best it can be.
