so frustrating
.... I was hoping this 3D printing was a little bit easier.... nah ja ..... the story continues.
@ Greaybeard: I am using the white ABS from Prusa , I expect this is a good quality. After I get some good prints , than my plan is to try out some different brands.
The reason I want to use ABS , is that I mainly bought my 3D printer for model airplane parts, so they need to be a bit sturdy ( vibrations) but the most important s the heat, the parts will be in the full sun with high temperatures for a day. I understand PLA is a no-no for that , PETg could be a solution as well. I don't really want to print in PLA , since I will not likely print in PLA in the future for the reason above.
The part is quite big , it spans the whole diagonal of the bed ( 25 cm long) , my printer is in a full enclosure and also the door it "airtight" , there is no air-drought. I don't think rotating the part will make a difference.
@ Airscapes: the STL file is 9MB big, I can not attach it here. Is there a simple option I can upload it somewhere?
I also used 2 days ago the settings from Doug, but I needed to cancel the print. This happened on this trial:
Back to my trial from last night.
I split the part vertical, which made sense to me, so I could easily fix them together. Unfortunately it went t*ts up again. Initially it looked very good so I let it continue to print last night , but when I woke up...... again lots of plastic to throw away.
The top part is bad, lots of sagging . Maybe I need to alter the bridge settings?
Also an issue with crashing of the Y-axe, 14x my prusa detected it. and it also shows in the model. I think it is due to the speed. I bumped it up again to the (standard) 4800mm/min, previously I had set it to 3500. Next try will be with 3500mm/min again.
Some one posted a couple of posts before to lower the acceleration/jerk. I notice with the infill it does , they are very short/ violent moves. It doesn't look right . Anywhere I can change this?
I will now try to split the part in half again , but horizontally this time.
Thanks,
Cor
