Stl, factory, and gcode files are in the attached zip.
If you preview the gcode, you'll see that layer 1 is fine. However layers 2-5 only build up the borders of the base, leaving the interior hollow. Layer 6 tries to put a cap on the top of the base to start building up the main part of the model, but the print totally breaks at this point because there's no support for layer 6.
