What I'd like to get is:
If I want to print with right HE (T0) configure the start and purge of the right HE (T0) with T0 HE heating and left HE staying cold.
If I want to print with Left HE (T1) configure the start and purge of the left HE (T1) with heating of the left HE and right HE staying cold.
Configure the start and purge of the right-hand HE (T0) and the left (T1) with HE heating of R/L in case I want to print in dual extrusion.
From what I have experienced so far I think I must set the start / end Gcode scripts
These basically depend on the auto-configure extruders setting and it seems logical to me, since I want a startup script if I want to print with R-HE, a different one if I want to print with L-HE and a different one if I want to do the both HE for dual printing ..
In the documentation and here I read that you can set the temperatures of the different "tools" in the start gcode and in this case then S3D does not do it automatically ..
Well, I'm almost there, this is my start gcode for R-HE (T0)
With the variable [extruderX_temperature] I read the print temperature from the print controller (T0 / T1) and use it in the start gcode
;Gcode R-HE (T0)
M280 P0 F160 ; Reset BLTouch
M104 S0 T1
M109 S[extruder0_temperature] T0
G92 E0; zero extruder
G28 ; Autohome
G29 ; Autolevel
G1 X-10 Y15 F5000; move to purging position
G1 E20 F150 ;purge the filament a bit before starting print
M530 S1; Start print
Here I set the heating of the T0 and I say to wait for temperature, I also set T1 to zero. The plate is arranged by S3D
Same for T1:
;Gcode L-HE (T1)
M104 S0 T0
M109 S[extruder1_temperature] T1
G28 ; Autohome
G29 ; Autolevel
G1 X0 Y15 F5000; ; move to purging position
Here I set the heating of the T1 and I say to wait, I also set T0 to zero. The plate is arranged by S3d
In order to use autoconfig correctly with [extruderX_temperature] variable for both DX and SIN, I have to set the print temperatures of the two controllers on the temperature tab in S3D.
The problem is that if I run the autoconfig for the R-HE (T0) S3d adds heat T1 at the temperature set for T1 taken from the temperature tab ...
Vice versa for T1, it also heat T0
Let's say that I want to auto configure R-HE with the start script above, the gcode generated by S3d is
; G-Code generated by Simplify3D(R) Version 4.0.1
; Jul 7, 2018 at 7:02:08 PM
; Settings Summary
; printExtruders,Right Extruder Only
; extruderName,Right Extruder T0,Left Extruder T1
; extruderToolheadNumber,0,1
G90
M82
M106 S255
G4 P500
M106 S0
M140 S80
M190 S80
M104 S230 T0
M104 S0 T1
M109 S230 T0
G28 ; Autohome
G29 ; Autolevel
G92 E0
G1 E-5.0000 F3000
G1 Z0.300 F1002
; process Color1
; layer 1, Z = 0.200
M104 S230 T1
;G4 P1000
M105
T0
; tool H0.200 W0.460
; skirt
So at the beginning of layer 1 S3D set:
M104 S230 T1
And it heats T1 not abeying what I set in start gcode (M104 S0 T1)
Where am I wrong?
thanks
pietro
