To summarize, is it possible to do any of the following?
- Change extrusion multiplier for perimeter only
- Change extrusion multiplier for infill only
- Change extrusion multiplier for top/bottom layers
Yes, you can do this. Just setup a new extruder on the Extruders tab, but make sure to use the same toolhead number as the prior extruder. That way they both use the same tool, but now you can configure the extrusion multiplier for each one differently.
Then you just assign whichever extruder you want to infill, outlines, support, etc
-No
-Yes
-Yes but not without effecting perimeters.
I also want to change perimeters extrution without effecting top/bottom layer.
But not possible as for now.
A must for good prints with E3D volcano.
