Michael_N
2 problems really
I have a Replicator 2X Printer dual head
Problem 1.) The left extruder fan runs continuously ??? I have asked and asked Makerbot but can never get an answer from them....
Problem 2.) Having an issue with a print [see images] and cant seem to get it cured so it would print correctly....
07182017.stl
(527.38 KiB) Downloaded 229 times
RoundPart.fff
(30.09 KiB) Downloaded 294 times
"Remember The Vets who fought for our Freedom" ... Intel I7 980 OC'D to 4.3 GHZ, Water Cooled, Gigabyte MB
132 gig ram, 5 HD's, GTX 1080, (8gig ram) GTX Titan-Z (12gig ram), LightWave 2015, 32 and 64 bit.
Michael_N
Re: 2 problems really
2nd image
As far as the print this can be solved by increasing the infill density and/or adding more top layers. Also the type of infill will have an effect on this.
On the fan, do you mean the left one of the two that are on the front? Normally these are set to run once the temp reaches ~50c.
To supplement the answer given by whirlybird.....
By default, the makerbot dual extruder has three fans....one fan on each of the extruders to stop the feed side of the extruder from heating up (and melting the filament before it gets into the head!), and one user controllable cooling fan.
The two extruder cooling fans...the ones facing the front of the printer, ,,will run whenever the relevant extruder head is above 50 degrees C. They'll start early on in the warming stage, and remain running after the print has finished until the head temperature falls below 50 C.
The third fan...the one fixed to the LHS of the head assembly, is the fan the slicer has control over...and is controlled from the Cooling tab in settings.
I have seen an add-on available for the 2X that is a mount and duct for a second cooling fan that plays directly onto the print at the right hand extruder nozzle. I have no experience of this...or as to whether it can be controlled separately to the LHS cooling fan.
And regarding the printing issue, I concur with the answer given.
Hope this helps......
