LarryC
[SOLVED] Reloading model with multi processes fails...
I'm not sure if I'm missing something, but I loaded a model, duplicated it once, then created three processes for it. After preparing/printing it, it worked just fine, but the model was missing a couple of holes so I edited my model and saved it. The height and OD's remained the same if that matters, I just added a 3mm hole in the side of the model. In S3D I removed the models and then reloaded the newly created version of the model, again I duplicated it. My processes remained in S3D so I double checked them to be sure nothing had changed which they hadn't, but when I click prepare to print, my screen shows that there's nothing to print. It's as though there's no model loaded even though there are two models technically. I tried different spacing between the copies to be sure spacing wasn't an issue but it's not producing any code to print.
Am I supposed to start from scratch on each print? Meaning I just close S3D and reopen it? I really hope not... Thankfully it was only two models, and three processes, but this is not what I'd expect.
<Edit to add that I'm using Win 7 x64 if'n it matters...> <Edit to add once again, an ID10T error caused this message to be created :oops: >
Re: Reloading model with multi processes fails...
Save everything to a factory file....and attach the file to a post so someone can take a look at how you have things set up.
File menu.....Save factory file as>
LarryC
Sorry, it was something to do with Fusion 360, I just re-edited the model and saved it, when reloaded into S3D for the third time it now works as expected. For what it's worth, I was playing with duplicating the body (model) in F360 and did something wrong. It's all good now, I'll edit my subject to reflect it after this message. Sorry for the false alarm.
