WhiteHare
How do I get gyroid infill pattern in Simplify3D?
https://mattshub.com/2018/03/15/gyroid-infill/
Apparently the Prusa Slic3r has it, but I'd rather use Simplify3D if I can.
Anyone?
WhiteHare
Re: How do I get gyroid infill pattern in Simplify3D?
It turns out to have better strength characteristics than any of the other infill patters:
https://www.youtube.com/watch?v=upELI0HmzHc&t=8s
SWCNT
S3D doesn't support gyroid as an infill option. Thanks for posting that video, it was interesting, but I don't think the conclusion was gyroid is the best infill. "Strength" is extremely design and function dependent, and there's a lot of other variables that were not commented on that can determine the "strength" of a component. That video proved that if you print a cube, with the same settings as he did, and that part will undergo compression, then gyroid is a good option.
