When I try to print a model with support, raft, and ooze shield the ooze shield does not print until after all the raft layers are complete. This by itself wouldn't be a problem except the ooze shield prints outside of the raft, not on the raft. This of course fails because we're already several layers above the bed surface and all you get is air printing.
- Raft and model are PLA (primary head)
- Support is Polysmooth PVB (secondary head)
- Ooze shield is both heads, 2mm from model -- which should include the raft, right?
If I go layer by later in the print preview, it is very clear the ooze shield isn't printed until layer 5, and then outside the bounds of the raft.
