I have a machine with a heated build chamber. It's controlled by M141 commands.
To have the correct first layer nozzle height clearance the machine must be heated before printing begins to let the Z axis threaded drive rod expand first.
I added this to the 'start code' script
M141 S70
M141 H0
But I found that the machines bed heater comes on first regardless, then the extruder, and then finally chamber heating is only activated when printing commences ( which is too late).
So the code is not running at the real starting point of the process.
Anyone know how to change that ?
S3D V4.0.1
