Very Interesting... Hard to say why it's not working for you. You may need to tweak the Marlin firmware...
I looked at the A8/etc printers and, except for some things, they basically look like the Hictop printers I built from kits.
Some of the same parts such as the bearing mounts and the hot-end carrier appear to be identical.
If they are the same, Given that you indicated you're building a printer, you may be interested in parts I designed to modify mine to accommodate a V6 hot-end.
The parts and links with video are at
https://www.thingiverse.com/Still_Breathing/designs.
