maestro72x
Export basic settings for review
Lots of times we have issues with our print.. would be great if we can export or post our settings to facebook 3d printing groups to get help from others.
Even if its just a popup of predefined group of settings that is formatted in a clean manner so others that see our settings can help with your printing issues.
Ie:
NinjaFlex Settings Simplify3d:
Nozzle Diameter: .40mm
Extrusion Multiplier: 1.00
Retraction: On
Retraction Distance: 1.50mm
etc.etc.etc.....
Re: Export basic settings for review
The G-Code header of your g-code file has all of the settings in a readable format. If you don't wish to display all of the settings there, you can always utilize the {STRIP} command to specify which settings you don't want to see in your g-code file.
more on STRIP: viewtopic.php?f=8&t=1959
maestro72x
Needs to be a simple (and customizable) export of the most important settings. We do not need every setting listed in the gcode as its overkill.
Needs to be simple for the masses, w copy to clipboard.
