The V6/Nozzle at home position (set by the limit switches) is 10mm and 5mmm off the bed X/Y respectively.
I iterated on various settings and ended up with prints that are properly centered on the bed.
Everything is perfect and prints great
However, the Print-Preview representation in Simplify is not how it gets printed nor the same as shown before Print-Preview.
Because of the V6 offset and clips holding the glass, the maximum print area is 192x226. Thus, I set the Bed size to 192x226.
To compensate for the 10mm/5mm V6 offset, I set the Origin Offset as shown. I could/should adjust the X-axis another 2.5mm, but, it’s good enough.
The problem is the Y-offset with respect to Print-Preview
Why? What needs to change?
