i have a problem, at the end of each path the material gets "stuffed".
Please the attached pictures. I palyed around with speed, Outline overlap and temperature but it did't help.
Does anyone have a tip for me?
I think that is caused by deceleration of the axis to the end of the path, and then again acceleration
away on the next path. Try to play a little with the acceleration settings of the firmware. Mostly
faster acceleration and deceleration will make this effect less visible.
