Simplify3D doesn't presently perform batch processing. In this case, how would batch uploads be any different from individual uploads?Deneteus wrote: ↑Fri Sep 28, 2018 6:52 am I would like the ability to not just send files but to manage batches of files that need to be sent to Octoprint.
Especially when you are trying to print all the parts for another printer and you need to make sure that the next batch that finishes gets sent to the printer. Or in some cases multiple printers. So I can send to 2 or more Octopis based on the batch.
Slicing each model / build into printable files and uploading seems it would be just as efficient if the uploading was automated. Assuming, of course, that the octoprint login is linked to each machine's profile. Then depending on which profile was used to slice, the correct network location would be chosen for the upload.
