jimc wrote:Toby set your perimeters at the layer height you want, say .15 then in the infill section set sparse infill to 2. This prints your infill every 2 layers but prints it thick and doubles the layer height. With spars infill at 2 on a .15 layer height then your infill prints at .3 and saves a bunch of time since its only printed every other layer.
Cool idea... but what about supports??? Based on how we all assume it works supports will also be .15mm layer height. Using 2 processes not only can we all set the infill at .3mm we also can get the supports at that lower res...
Wait!
There's a print sparse support too!
One big difference though... when I use 2 processes and set it so that only the outer perimeter shell is a real low layer height I get significant time savings in the print. Using Sparse infill all the perimeter shells will be at the lower layer height and the savings time wise is not nearly as big.
Thanks for the input! Gotta love S3D.
