Hello, I own a Prusa Mk2.5 a Ender 3 and a CR-10S I have the correct profiles for my printers im printing fine on all printers. I have small issue with when i use my ender 3 profile. the line it puts down before it starts the skirt. Primer line i think its called? i would like to change direction of the way that line gets put down. right now the primer line im going to call it. runs in x direction and wants to run or get really close to my clips i need to change this to Y direction that way it dont even come close. my Cr-10S profile runs in y direction so no change is needed on the cr-10 i only have this issue with the ender 3 profile.. My Mk2.5 dont use clips so its also fine. I have tried placing the clips in different places they work better for me at the top and bottom of the build plate.. Ender in home position dont leave no room on the corner and no room on the sides as well if i could just flip that primer line from going x axis direction to y axis direction
Thank you in advanced....
