iZz0s
[FIXED] retraction broken?
since 4.1 i got weird really big blobs on layer start after the retraction.
no problems here with 4.01.
S3D-Alex
Re: retraction broken?
Can you please post a Factory File that exhibits this issue?
iZz0s
Im since today On vacation Till sunday but i can attach a picture where you See this Problem on the bottom layer.
Problem isnt present with the 4.01 Version and i havent changed Any settings, too.
Twuen
Are there any news regarding this issue?
I have the same problem, that in certain parts the retraction seems not to work but a massive deretraction!
G92 E0.0000
G1 X241.331 Y224.690 E0.0488 F1680
G1 X240.917 Y223.463 E0.3073
G1 X242.129 Y222.961 E0.5690
G1 X241.852 Y223.639 E0.7151
G1 X241.323 Y224.935 F1680
G92 E0.0000
G1 E-0.0714 F2700
G1 X241.331 Y224.690 F1680
G1 X241.695 Y224.024
; feature inner perimeter
G1 Z10.900 F1002
G1 X239.262 Y226.591 F7200
G1 Z10.600 F1002
G1 E6.2286 F2700
G92 E0.0000
G1 X239.732 Y227.832 E0.2648 F2940
G1 X239.971 Y227.758 E0.3148
Twuen
I just played with the settings once more and figured that the complete retraction is changing when I change the value between 6.40 and 6.45:
retract 6.45 or more:
G1 X240.750 Y258.225 F1680
G92 E0.0000
G1 E-0.0214 F2700
G1 X239.968 Y254.302 F1680
G1 Z0.900 F1002
G1 X241.928 Y257.995 F7200
G1 Z0.600 F1002
G1 E6.2286 F2700
G92 E0.0000
retract 6.40 or less:
G92 E0.0000
G1 X239.971 Y254.320 E-6.4000 F1680
G1 Z0.900 F1002
G1 Z0.600 F1002
G1 E-0.2000 F2700
G92 E0.0000
AndersE
I get horrible blobs when both coast and wipe is on. turn off wipe if you use it? same problem then?
neotko
Clearly the wipe while retracting it's broken
https://twitter.com/neotko/status/1060867516422074368
I would stay away from 4.1 for a few weeks. S3D need's to push the level up and start with some good beta testers to avoid this issues.
AndersE
do you really think they will release an update soon? (before christmas...2019?)
gavatron3000
I'm finding I get blobs at unretraction points after travel moves. Use same factory file in 4.0.1 and it's perfectly fine
tomsdk
I can confirm that from 4.0.0 to 4.1.0 the retraction when leaving support and continuing on model layers, is missing. This results is that the support is "melting" together with the model, even if the space is several millimeters. (probably only visible on bowden printers, which rely heavily on retraction).
