The complete changelog is listed below. As always, follow the instructions in your confirmation email to download the latest update.
Happy Printing!
CHANGELOG
- Added auto-configuration options for Medium and High quality printing
- Improved accuracy for build time estimates
- Estimated print time and necessary filament are now displayed after creating a G-Code file
- Added ability to set min and max height for slicing
- Added new dialogs for slicing multiple FFF processes into a single G-Code file
- Creator now supports different settings for different models on the same build plate or even different settings for different vertical sections of the same model
- Added ability to exclude first layer temperature settings from G-Code files and set manually via the MCP
- Added requirement for first layer temperature setpoint if using stabilize at startup
- Fan speed blip to full speed now only occurs if new speed is less than 80% (no need for blip if new speed is already 100%)
- Per-layer preview now separates G-Code moves made during the custom ending G-Code section
- Preview support for homing commands (G28)
- Added display for layer number when using per-layer previewing
- Adjusted support algorithms so that support will always be placed directly on build surface regardless of lower separation layers setting
- Further slicer improvements for self-intersecting meshes
- Removed unnecessary Z-coordinates from G-Code output
- Added better debug output to status bar messages
- Removed empty serial ports from listing
- Changed "Primary Extruder Temp" to just "Primary Extruder" so it has a clearer relationship to Heated Bed
- Improved descriptions in Support Generation dialog
- Moved G-Code X/Y/Z offsets onto G-Code tab
- Added option for different X/Y and Z axis movement speeds (make sure to update/verify these settings!)
- Updated default retraction and movement speeds to improve print quality
- Added extra skirt outline to M2 profile to ensure stabilized flow prior to starting model
- Slower initial retraction for anchor point when starting a print
- Fixed bug where some temperatures might not be parsed from G-Code file depending on firmware settings
- Fixed bug with Print from SD Card command while monitoring temperatures
- Fixed bug where Temperature Monitoring could be inadvertently left on, interrupting startup communication
- Minor fixes for Z-lift retraction moves
