ashleyfoxcroft
Problems with 4.1, now reverting to 4.01
Using same models and print settings between 4.01 and 4.1, there are very noticeable gaps between the start and finish points of outlines/perimeters; there looks to be insufficient extrusion at the beginning of a line. I tried to compensate by reducing retraction & adding extra retraction distance or turning off retraction, but after several attempts (and half a day), the issue persisted. I then printed the same model. using same settings but generated by 4.01 and the problem went away. I then used Cura to slice the model using similar settings and there was no problem so I don't think my Printer or Filament was to blame.
mzakelj
Re: Problems with 4.1, now reverting to 4.01
Hm, where did you get older version. I have licence but i dont find the old version. It would be nice if we can acces older versions.
